Byrd R., "Alone"
A terrific story of human endurance. Admiral Richard Byrd is one of the great Polar explorers and is responsible for transforming Antarctic expeditions from the dangerous days of the heroic era to the comfort and safety available in modern Antarctic stations.
Byrd organised several American expeditions to Antarctica and built the research station Little America in the Bay of Whales next to the remains of Roald Amundsens base Framheim.
He did all this with little government support and paved the way for todays US Antarctic Program. In 1929 he became the first man to fly over the South Pole, and the first to see it since Scott left it in 1911.
In 1933, frustrated by the limited meteorological observations he could make at his coastal station he determined to establish a second base far inland. So was Advance Base born. Initially to be manned over winter by three men, time and material constraints resulted in a sole occupant over five months of winter: Admiral Byrd himself. In this book we see the hopeful but wary Byrd descend slowly into despair as unknown to him toxic carbon monoxide gas from his heater begins to slowly kill him. After recovering from a coma he realises his predicament and tries to nurse his broken, poisoned body back to health.
It is a harrowing tale as a bedridden and brain damaged Byrd tries to feed and water himself. He is forced to make the daily decision as to how long he can run his heater without further worsening his condition. Lying alone in the dark with only his thoughts for company he enters the darkest parts of the human psyche and somehow finds the strength to fight. All through this Byrd maintains his daily observations and his weekly radio contact with his colleagues at Little America. Tapping out morse code messages he hopes will disguise his desperate state and prevent a dangerous mid winter rescue.
ALONE
by Richard E. Byrd
Rear Admiral U.S.N. (Ret.)
originally published 1938 by G.P. Putnam's Sons
Contents
    Introduction and Preface
  1. 1933: The Idea
  2. March: The Decision
  3. April I: God of 2.5
  4. April II: The night
  5. May I: The Intimation
  6. May II: The Blow
  7. June I: Despair
  8. June II: The Struggle
  9. June III: The Proposal
  10. July I: Cold
  11. July II: The Tractors
  12. August: The Searchlight
Chapter Two — March: The Decision
Thereafter from the tractor fleet came an almost continuous stream of radio reports, mostly discouraging. Vexed by cold and drift and blizzards, and reduced to low gear on loose, newly fallen snow, the machines made slow going of it. About twenty-four miles south of Little America two cars narrowly escaped disaster in an unsuspected crevassed region; and about fifty miles out in a bowl-like depression named the Valley of Crevasses the party was compelled to take a long detour eastward to avoid blind crevasses whose roofs had been strong enough to pass Innes-Taylor's dog teams, but not the heavily loaded machines. On this jog, sixty-seven miles out of Little America, the Cletrac gave out entirely: a crankshaft pin, made brittle by the cold, sheared off; and, the necessary repairs being beyond the party's resources, the machine was abandoned. With it was lost 50 percent of the party's carrying capacity. Redistributing the loads as best they could, June and Demas pushed south in the other three tractors. Any chance of an extended southing was gone. The three surviving Citroens, June advised, had all developed mechanical trouble of one sort or another. The generators -- even the spares -- were worn out, the radiators were leaking, the anti-freeze solution had been lost, the drivers were cramming snow down the radiators to keep going, and one car was without headlights.
More vividly than the terse radio bulletins described, I knew what the men were up against. The sledgers, at Little America, hating the break with tradition, sneered at tractor travel as "limousine exploring." But, so far as discomforts went, there was little to choose between the two ways of travel. You could go faster and haul more in a tractor, and certainly you could do your exploring sitting down. But tractoring had its own punishing hardships, not the least of which was waiting exasperating hours for the blowtorches to thaw out the lubricants in the crankcase, rear end and the transmission, which the cold congealed to a rubbery toughness after the engine stopped. And sucking frozen condensation from the gas lines. And melting snow in the food cookers to make water for radiators that leaked like sieves. And leaving the flesh of your fingers on metal parts too delicate to be handled with clumsy mittens. And sitting as if trapped in a moving cab, waiting for the awful lurch, and the whroom of slithering tons of snow to warn you that a crevasse roof was letting go under the treads.
Even a demanding leadership can ask only so much of flesh and blood. The evening of March 21st, the tractor party reported that it was at a depot put down by Innes-Taylor's Southern Party 123 miles by trail from Little America. Almost at the same time Innes-Taylor wheeled in from the south, with just one day's dog rations on the sledges and a story of bitter cold and blizzards. That, I decided, was far enough. Let Advance Base be planted alongside this depot at Latitude 80 degrees 08' South, Longitude 163 degrees 57' West, just a hairbreadth off the Little America meridian. The distance was sufficient, the meteorologists decided, to permit satisfactory correlations. June was instructed to retrace his tracks and pick up the remnants of the Cletrac's load in the morning. The temperature where he was dropped meanwhile to 52 degrees below zero.
That night, between the hours June arrived at, and went from, Latitude 80 degrees 08' South, I made my decision. Advance Base would be occupied and, inevitably, by one man. With the tractors crippled and the sun due to quit us in less than a month, neither the means nor the time remained to stock it for three men as planned. The alternative of two men I again rejected for the same reasons I had rejected it before: that is, on the logic of temperamental harmony. The truth is that I myself did not dare to go as one of a two-man team. The other man might turn out badly, as indeed might I, in his eyes. Hating or being hated by a man whom you couldn't avoid would be a degrading experience leaving the mark of Cain in the heart. Feeling as strongly as I did, I certainly couldn't very well ask two other men to do what I wouldn't risk myself. It had to be one man, and that one myself, if for no other reason than that here again I could not bring myself to ask a subordinate to take the job.
The idea of letting Advance Base go by default was never seriously entertained. The expedition had planned too long and endured too much on its account for me to give up so easily, even though we had failed to push the base as far south as the meteorologists might have wished. Moreover, as I said at the outset, I was anxious for the opportunity to go. This was an experience I hungered for, as soon as I grasped the possibilities. But apart from that, I was better equipped, perhaps, than anyone else in camp to handle the job. The Base was my scheme. I had wet-nursed it from birth; and nearly everything about the shack, from the insulation to the double-action trapdoor, represented some pet notion. From Dyer, who had instructed me in radio, I had picked up enough primer information to enable me to keep in touch with the main base; and Haines had taught me how to take care of the meteorological instruments, which were mostly automatic, anyway.
As for the practical matters of existence, I felt that my service as an explorer had made me self-reliant. I don't claim that, like Thoreau, when he retired to his lonely hut at Walden, I was all prepared to build a house, lay a chimney, survey a field, and manufacture pencils. The fact is that I was not nearly as handy as I had imagined; but, for all my clumsiness, there were one or two improvisations at Advance Base that would have done credit to that scholarly experimenter and even to that inspired artificer Robinson Crusoe.
I was up all night rearranging my affairs. It was not as easy as I pretended. My break with the interlocking conveniences and practices of normal life would be clean and sharp and irrevocable. I had moments of heart-sinking doubt, particularly when I visualized what might happen to my family if I should fail. And this alone gave me pause. As to the moral aspects of my leaving fifty-five men leaderless at Little America, that did not trouble me a bit. My officers had a comprehensive idea of what was expected of them during my absence. We talked almost steadily from midnight to dawn. In charge, with the title of Second-in-Command, I put Dr. Poulter, the Senior Scientist. He is a physical giant of a man. Though attuned to the quiet of the university campus, he had the practical judgment and intellectual balance which are indispensable for the leadership of men who like to call themselves men of action -- as if by that they put themselves beyond the penalties of rashness.
Poulter would have under him a hard-bitten crew who were well able to take care of themselves. Misery Trail had toughened and schooled the new men as no other experience could have done; with them was a hard core of veterans of my other expeditions. Haines, the Third-in-Command, was serving on his third polar expedition, as was Demas. Noville, the executive officer, had served under D'Annunzio during the war, had been Superintendent of the Air Mail, and had been with me on the North Pole affair and the transatlantic flight. June, whom I appointed Chief of Staff, had flown with me across the South Pole. Bowlin, the Second Pilot, had been in the Navy sixteen years. Innes-Taylor had dueled with Zeppelins in London's war-time skies, and trekked the Yukon for the Royal Canadian Police. Siple, who was a scientists and trail party leader, and Petersen, who was a first-rate photographer, radio man, and skier, had proved their worth on the previous expedition. Von der Wall, another Navy man, knew what it was like to be torpedoed in the Atlantic Ocean, and Bob Young, another veteran as well as a retired British naval rating, had fought in the Battle of Jutland. And Rawson, though the youngest of the lot, knew what it was all about from four voyages into the Arctic. There were these and others like them.
To these men I could entrust the winter destinies of Little America without fear. For one thing, the winter night is ordinarily tranquil. No parties are in the field; the men are fully occupied in making preparations for the spring campaigns; and, secure from the blizzards and cold, life finds new and easy ruts underground. Moreover, I expected to keep in fairly close touch with them by radio. Hence, except for some special instructions to Poulter, I did not feel it necessary to draft a complicated set of regulations. My last general order to the camp, which was primarily intended to announce the line of command, covered less than three typewritten pages. It was a simple appeal to work industriously, conserve supplies, abide by the safety rules, and respect discipline. In conclusion, I said: "Every man in this camp has a right to be treated fairly and squarely, and the officers are requested to hold this fact in mind. In a sense our status is primitive ... We have no class distinctions as in civilization. What a man is back home does not count at Little America. He who may have failed back there has his chance to make good here; and he will not be judged by the position he holds so much as by the way he plays the game and does his job, however humble it may be. ..."
This order I finished on the morning of March 22nd, just before I flew to Advance Base. I did not have time to post it. Somebody read it to the men after I left. Noville, who had shared his quarters with me, helped me pack a few personal things -- several dozen books, a sextant, a couple of fine chronometers, a fine and rather elegant fur flying suit that a friend had given, a shaving kit, my own set of phonograph records, and various odds and ends. There was no ceremony about it whatever, if only because Byrd expeditions never stand on ceremony. The cook shouted cheerily, "Remember, Admiral, no class distinctions at Advance Base!"
Bowlin and Bailey were fretting in the Pilgrim. Although hot oil had just been poured into the engine, it chilled rapidly; the temperature was 43 degrees below zero and dropping. I remember glancing at my wristwatch as we left the ground. The time was 10:35 a.m. (180th meridian time). Bowlin, as if sympathizing with my mood, made a banking turn around Little America before squaring away for the south. I took in every detail. If I had created anything tangible and unique in life, it was the sprawling, smoke-spewing, half-buried city called Little America, pocketed within the eastern heights of the Bay of Whales. It heartened me just to look at the place. The job of reoccupation was nearly finished, and I need have no further worries on that score.
A quick glance to the north confirmed what I already knew: that the Ross Sea was frozen to the horizon, and any danger to Little America from further disintegration of the Barrier had passed. Beyond Amundsen Arm, where the Bay of Whales curves in behind, and to the south of, Little America, we picked up the tractor tracks, the crimp marks of the caterpillar treads standing out clearly on the white, virginal flesh of the Barrier. Every third of a mile was an orange trail flag; and every twenty-five miles was a tall snow beacon, surmounted by a big orange banner on a bamboo pole, with a line of burgee and pennant flags running to the west and east. These were depots in which Innes-Taylor had cached rations for the main spring journeys: the markers -- the Antarctic equivalent of roadside stands and route signs -- on the Advance Base road. Sixty-seven miles out, Bowlin dropped low over the foundered Cletrac. Demas and Hill, who were still slaving over the engine, crawled from under a canvas apron and waved a greeting. Not long afterwards a dark speck on the horizon resolved itself into a cluster of tents -- Advance Base.
Where Advance Base lay, the Ross Ice Barrier was as flat as the Kansas Plains. Snow rolled on forever to meet the sky in a round of unbroken horizon. Here was the spaciousness of the desert; the spaciousness, you might say, of the raw materials of creation. Against it the huddled clump of tents, tractors, dogs, and men was just a pinprick in infinity. Although this was all familiar stuff to me, it was not until then that I had an intimation of what I was in for. On the verge of starting a dangerous task, I suppose that even the most unimaginative man must know that instant of premonition when the last unresolved forebodings come swimming out of nowhere. Whatever it was, I dismissed it before the skis touched. Innes-Taylor and Siple were coming forward to meet me; and Bowlin was impatient to be off, lest the cold stop his engine. Fifteen minutes later the plane was in the air. The vapor from the exhaust trailed behind like an enormous banner, which hung long after the plane had vanished into the lusterless, low-swinging sun.
"How's the shack coming?" I asked Siple.
"Slowly," he said. And, looking at him and at the other men who came up to say hello, I saw that their faces were yellowed by frostbites, and the cracked lips within the parka hoods wore mirthless grins.
"Everybody but Black," Innes-Taylor said. "He's got a bum knee. But, if it's all right with you and if we can get this shack up fast, I'd like to get my party out of here in a day or two."
"We'll see," I said. I knew, without being told, what was in Innes-Taylor's mind. He and his three men -- Paine, Ronne, and Black -- had been on the trail over three weeks, enduring temperatures exceeding 50 degrees below zero. I gathered that they had had a rough time of it, largely on account of defective zippers on the sleeping bags. Ice had gathered in the bags. To sleep more than a few minutes at a time was almost impossible; and lying still meant freezing to death. Hence, as the party still faced a five-day journey back to Little America, I promised Innes-Taylor that I would not hold him any longer than was absolutely necessary. Not alone for the men's own sakes, but also out of consideration for the dogs, of which he had two dozen tethered around his tents.
June, with six men and two tractors, was somewhere on the trail, making for the Cletrac. So eight of us were available for the preliminary work on the base -- Innes-Taylor's party, myself, and Siple, Tinglof, and Petersen from the tractor group. A pit fifteen feet long, eleven wide, and eight deep -- big enough to take the shack bodily -- had already been dug before I arrived. Sunk in the snow this wise, the shack would be out of the wind and the drift, which mounts with the speed of a tide around any upraised object.
Luckily for us, the shack had been designed for quick assembly. Tinglof and Siple were laying the floor sections when I took charge. Putting up the walls was a simple matter of heaving the numbered sections into the right places and bolting or spiking them together. Afraid that a blizzard might strike during the night and fill up the pit, we worked like hell. That afternoon the temperature sagged through the minus 50's, and our breaths made a continuous fog in the pit. We watched each other's faces for the dead-white patches of frostbite. "A blossom on your nose, Petersen," somebody would say. Petersen, until then unaware of the danger, would mold the flesh with his finger tips, his fingers stinging the instant they left the warmth of the gloves; then the blood would come surging back into the affected spot with stabs of pain. "Jesus," he would say. Then back to work.
Hard as we pushed, the shack was still unroofed when the night rushed down from the South Pole at 5 o'clock. By then the temperature was 61 degrees below zero. We worked on by the light of pressure lanterns and the heat of primus stoves. Then the lights died when the kerosene froze; and a flashlight, the battery frozen, went out in my hand, leaving us in darkness. Tinglof stumbled and fumbled in the caches until he found two gasoline blow torches which June had left behind; by their feeble glow and with the heat from the flame near our legs, we carried on.
It was verging on cruelty to drive so hard, but we had to have shelter before we could sleep. Tinglof's mittens were filled with ice; when he bared his had to tip in a spike, I saw that the skin was covered with puffy yellow blisters. It was the same with Siple, who was putting the stove together. Before the bolts would turn, he had to close his mittens over the metal to take the frost out; his hands became swollen lumps, and again and again I saw him, biting his lips against the pain, slip them under his parka to snatch at the body's heat. Paine's face and helmet looked like a solid lump of ice. Ronnie's lips were cracked and bloodied. All of us were coughing, not from colds but from the super-chilled air that tortured the lungs as we breathed more deeply from exertion.
No exaggeration, it was brutal work. I climbed out of the pit to fetch a piece of meteorological equipment from one of the caches. While I was ransacking the pile, my nose and cheeks froze. I stood up a moment, kneading the flesh. A ghastly blue reflection showed over the excavation, and the way smoke from the torches and freezing breaths spiraled up through the unsteady light made me think of that terrible frozen pit in the Divine Comedy, which leads down past Lucifer to the lost souls. A low moan came out of the darkness. I reached into the chest pocket of my parka for the flashlight. Nothing happened when I flipped the switch; the batteries were still frozen. But ringing me were dozens of anxious eyes, glittering with ravenous light and framed within the restive shadows of the wolf dogs. My heart really bled; for they had to sit and wait, spaced out on the steel tethering line. But I could do nothing for them, except promise myself to start Innes-Taylor north just as soon as I could.
The single door of the shack was made to face west -- for no reason at all, so far as I can remember, except that after the pit was sunk, the hut simply had to face west to fit. The pit was dug overly wide to accommodate what I was pleased to call my "veranda," created by projecting the roof some two feet past the wall on the west side. This would give me access to a tunnel system and to a trapdoor set in one corner of the projection and reached by a ladder. If I do say so myself, the hatch was a clever double-action arrangement. You could open it by pushing up; or, if the drift was packed too tightly overhead, you could pull it down by removing two pegs. "Look, Admiral," Czegka had exclaimed, when he first demonstrated the door, "Push him up. Push him down. No danger, now, of being buried alive in a big blizzard."
It was nearly 1 o'clock in the morning and 63 degrees below zero when we were done with securing the roof. The job was infernally complicated as a result of several sections' having been warped in transit from Little America. The door, which had been made to shut tight on bevels, just as on an ice box, now couldn't be made to latch at all. (Nor did I ever succeed in closing it entirely during the seven months I occupied Advance Base). I was worried, too, finding that we had blundered in calculating the depth of the pit. Instead of being flush with the surface, the roof stuck up a good two feet above it. That would make for troublesome drift. The mistake was past remedy, however; so I let is pass. Siple had the stove rigged up and burning; and though it would be a long time before the chill would go out of the shack, we all went below to enjoy the little warmth it gave off. None too soon, at that. Innes-Taylor remarked casually that he thought one of his feet was frozen. And indeed it was, as we saw as soon as he peeled off his mukluks (boots). I tried warming the foot with my hands and working the flesh gently, but without effect. That superstitious business of massaging the skin with snow isn't done in the Antarctic. At sixty below, snow takes on a hard, crystalline structure; you might as well use sandpaper. What we tried in this case was a method familiar to all polar travelers. Paine, I think it was, unbuttoned his shirt, and let Innes-Taylor slip the foot against the warmth of his stomach. He held it there fifteen or twenty minutes, until the circulation revived with a pounding pain that brought sweat to Innes-Taylor's forehead.
That night, after Innes-Taylor, Paine, and Ronne had repaired to their own tents, which were pitched just a few yards from the roof of the shack, five of us stretched out our sleeping bags on the Advance Base floor. The instant the fire went out the cold settled with the force of a blow. "You'll freeze to death in this dungeon," Petersen remarked cheerfully from his bag. But, having lived in the shack at Little America, I knew otherwise; it would be comfortable enough as soon as the frost went out of the walls. The shack was as tidily built as a watch. Although enclosing over 800 cubic feet of space, it weighed only 1,500 pounds; the hut and everything about it had been kept as light as possible to make for easier transportation. Fine white pine stiffened the frame and flooring, but the rest was mostly shell. The walls were only four inches thick. A three-ply veneer, one-eight inch thick and composed of a layer of wood between two strips of cardboard, sheathed the outer and inner walls. Loosely wadded in the hollow between was insulation of kapok which resembles raw cotton. Tacked to the inside walls was a green fire-proof canvas fabric. The ceiling and the upper walls were a bright aluminum, to reflect light and heat. Czegka had remembered everything. And that night, sleeping for the first time at Advance Base, I had reason to think well of what he and Tinglof had created.
Next morning we were roused by the beep-beep of the tractor horns; June and Demas were back with the Cletrac's load. Considering the night they had spent on the open Barrier, the crew were in an astonishingly cheerful mood.
"It's amazing," young Joe Hill observed, "the way these jalopies keep moving. Even when they're falling apart."
"He means," Skinner interrupted, "the way you can get 'em started after they've stopped. Every time the engine dies, you think it's the finish. But if you tinker long enough, damned if they don't turn over again."
Although spoken in jest, the news was disturbing. The return trip to Little America would be difficult enough at best; and considering the present killing temperatures, the chance that mechanical breakdowns might maroon some 20 percent of the expedition's personnel on the trail was one I found hard to accept. I had only to look at the men to visualize what they had been through. They were like scarecrows, the way the torn windproofs, caked with frozen oil, fluttered about their legs. Their hands were eloquent, Demas' and Hill's particularly. The flesh had been burned and shriveled by the frost in the metal which they were forever handling; the nails had turned black and were rotting away; and blood was oozing from sodden blisters.
June and Demas, however, were reassuring. "I'm not worried," Demas said. "With a break, we'll have all three cars in Little America twenty-four hours after leaving here." If anything did go wrong, plenty of help was available at Little America; and, anyhow, Innes-Taylor's party would be bringing up the rear. Nevertheless, the situation was not to my taste; for at that season in the Antarctic the line between safety and a major mishap is hair-thin. "It's too damn cold for men to be in the trail," I said. "I want all of you out of here within forty-eight hours."
Actually only one big job remained to be done: cutting out and stocking two supply tunnels, one for fuel, the other for food and miscellaneous stores. The tunnels were laid out in parallel, running west from the opposite ends of the veranda. With fourteen men to help, the job didn't take long. They were each about thirty-five feet long, about three feet wide, and deep enough for me to walk erect. The food tunnel was to the south. To make this we mined out a subterranean passage, leaving a vaulted roofing of snow about two and a half feet thick. Here provision boxes were stacked in recesses along both walls, one box on top of the other, with the marked sides facing out so that I should be able to tell the contents at a glance. At the far end we dug a hole for a toilet, which was distinguished, in Petersen's phrase, for "the open plumbing." Into the other tunnel went the drums of fuel, which were rolled into alcoves let into the sides. As soon as the drums were underground, we roofed this tunnel with coarse paper laid across wooden slats, and anchored with snow blocks. The rest of the supplies were dumped through the hatch into the veranda.
As the stuff dropped underground, Siple and I made a rough check. The variety of things was really amazing: 350 candles, 10 boxes of meta tablets, 3 flashlights, and 30 batteries, 425 boxes of matches (safety and wax), 2 kerosene lanterns, a 300-candle-power gasoline pressure lantern, 2 sleeping bags (one fur and one eiderdown), 2 primus stoves. Also a single folding chair with an air cushion which the tractor men generously donated, 9 fire bombs and a Pyrene fire extinguisher, 3 aluminum buckets, 2 wash basins, 2 mirrors, a calendar, a small fireproof rug, 2 candle holders, 2 whisk brooms (for brushing snow off my clothes), 3 dozen pencils, a 5-gallon can stuffed with toilet paper, 400 paper napkins, a box of thumbtacks, and one of rubber bands. Also, 2 reams of writing paper, 3 boxes of soap and laundry chips, a thermos jug, 2 decks of playing cards, 4 yards of oilcloth, pieces of asbestos, 2 packets of tooth picks. Altogether, the food supplies comprised approximately 360 pounds of meat, 792 pounds of vegetables, 73 pounds of soup, 176 pounds of canned fruit, 90 pounds of dried fruit, 56 pounds of desserts, and half a ton of various staples, including cereals. There were these things, and a good deal more besides.
While the rest of us were hurriedly stocking the tunnels and shack, Waite was rigging the radio antenna, which was about two hundred feet long and strung on four fifteen-foot bamboo poles. He finished in midafternoon; then he installed the transmitter and receiver. With Siple's help I personally set up the meteorological equipment, of which there was a great deal. "My God," remarked Dustin, pausing in fascination, "that's going to a lot of trouble to find out what my feet keep telling me: that it's a damn cold place."
The end of the second day -- March 23rd -- saw Advance Base just about ready to take over its job as the world's southernmost weather station. That night we had a farewell banquet for Innes-Taylor's party, which was scheduled to head north in the morning. And, because this was made to seem a gala occasion, my guests managed to talk me out of the choicest delicacies in my larder -- a turkey and a couple of chickens which Corey, the supply officer, had contributed out of the goodness of his heart, thinking I might like to celebrate one or two holidays. The meat was rigid as armor plate with frost, but the hard-boiled tractor men were prepared to deal with that: they thawed it out with blow torches. Elected chef by acclamation, Innes-Taylor presided over five primus stoves. Nine men sat cross-legged on the floor; and five, who couldn't find room to sit, ate standing up. Judging by the belching of the dog drivers, the meal must have been a satisfying change from the soupy hoosh which they had lived on for nearly a month. "It's just having something sticking to your ribs that makes the difference," Paine remarked. "And for my third helping I'll take the neck, Captain, if that isn't your dirty thumb that I see."
The dinner, as it turned out, was premature. During the night an easterly came rustling through the cold; and when we awakened, it was making into a blizzard. You couldn't see fifty yards, and the wind's edge, at 28 degrees below, was sharp as a knife's. Because travel was out of the question, Innes-Taylor decided to stay another day. That night, as the night before, ten men slept in my shack. Tinglof was stretched out under a table; Black was curled up behind the stove; Waite was sprawled under my bunk; June went to sleep sitting up in a corner; and the others, laid out like mummies in the sleeping bags, covered the floor from one wall to the other. I shall never forget that night. My guests set up such a racket of snoring that I was finally driven out of the shack. So I went topside to see how the sledges were faring.
The blizzard was slackening, but the wind was still high, and my flashlight made only a blotch of light in the thick drift. But off to one side I could hear the sides of the tents cracking like wet sails in a gale; and I groped in that direction until I came to the tents. Paine was muttering something in his sleep, and Innes-Taylor moaned and twisted away from the beam of light as it fell across his eyes; but Ronne was sleeping the full sleep of a good Norwegian. As I was drawing tight the pucker thong closing the sleeve-like entrance, something brought me erect. It was a sound breaking taut and vibrant over the voice of the wind. Then it swelled again, keyed to the gale, but richer and compounded of many voices. The dogs, of course.
I floundered until I found them -- three teams in parallel files, each spaced out on a tethering cable between gee poles rammed deep into the crust. The dogs fell quiet when I came through the smother. Perhaps the knowledge that human beings were still about reassured them. As I went down the tethering lines, playing the flashlight, I found each dog curled in a tight ball, with his back to the wind, his muzzle tucked against his belly, and the drift making a wall around him. It did not seem the part of mercy to keep them on the Barrier this late in the season. Yet, wait they must until the weather improved. A lull came in the wind; and for an instant, as the drive of the drift slackened, I saw clear sky swarming with stars directly overhead. Yes, the weather might be mending. In that case, the Southern Party would be homeward bound in the morning.
Maybe Paine's great leader, Jack, guessed that, too. For he heaved suddenly to his feet, shook the snow off his back; and then I heard the indescribably wandering cry of the husky. In an instant all twenty-four were up and joining in; they filled the Barrier with a melancholy wail that was not the melancholy of sadness but rather of hunger and lust. Yes, indeed, there would be a run to the sledges on the morrow.
Sunday the 25th came on clear, still, and cold. "Well, she's certainly covered now," Tinglof reported after peering from the hatch. A foot of drift lay over the roof, and little light came through the three skylights set in the ceiling. The thermometers stood at 48 degrees below, and Waite said, "They lie in their tongues." Innes-Taylor finally got off; and later in the day Demas, Hill, and Skinner left in one of the Citroens to make a last effort to salvage the Cletrac, leaving June, Siple, Waite, Petersen, Black, and Dustin, with two tractors, still at Advance Base. They lingered only long enough to make everything shipshape. Waite finished his test radio contacts with Little America; Siple was through tinkering with the stove; the meteorological equipment was already spinning out its tale of wind and cold; and finally, Monday noon, in the middle of lunch, June remarked quizzically, "Well, we've done just about everything that needs doing, and a lot of things, I suspect, that needed no doing at all; so I guess it's time to shove off." As simply as that he disposed of a problem in polar etiquette for which the rest of us could not find the right meaningless phrase.
Directly after the noon stand-up meal, the tractor crews made ready to leave. The temperature was 64 degrees below zero. Both cars were half buried in drift, and we were a long time digging them out. Even with blow torches playing on the crankcases and canvas aprons draped around the chassis to hold in the heat, it was two hours before the engines would turn over. The party made a false start at 5 o'clock, only to come limping back two hours later. I was underground when I heard the sound of the treads reverberating through the snow. It gave me a nasty turn because I was desperately anxious to have them on their way to Little America. But, when they returned to the shack and told what had happened, I understood that they had made the wisest choice. Three or four miles out the radiator froze in June's car, and in unscrewing the cap he scalded one hand in the geyser that spouted up and froze the other trying to nurse it. So he decided to return and give his hand a chance to heal in the warmth of the shack. The party stayed all night, sleeping in their clothes. The engines never stopped running, and Waite and Dustin were up all night to tend to them. "If you let them stop," Demas snapped, "you may be here all winter." I didn't bother to go asleep, but wandered around with the two men on night watch.
Wednesday the 28th, at high noon, the cars put out again; this time they did not come back. In some respects the departure had been as casual as speeding the departing weekend guests. Whatever of importance required saying had been said long before. The one afterthought that had bothered me after quitting Little America was the possibility that I might not have been emphatic enough in my instruction that no rescue efforts were to be made on my behalf in the event of radio failure. This order I impressed again upon the Advance Base party. "I don't know much about radio," I said. "The chances are that I shall lose communication for short periods, maybe for good. Don't let that worry you. No matter what happens, remember that I'm a lot better off in this shack than you are apt to be on the Barrier, and I give you a hard-and-fast order not to come for me until a month after the sun returns. I've got an abiding respect for the Barrier, and I don't want any act of mine to put you in jeopardy from it during the winter darkness." And to make sure that there was no mistaking my earnestness, I repeated the gist of this before they started out afresh.
Siple and Waite lingered behind after the others had boarded the tractors. If they meant to say something they never got it out. An impatient voice snapped, "For Christ's sake, get going"; and first Siple, then Waite, after mumbling an unintelligible amenity, hurried off.
I stood at the trapdoor and watched the two Citroens move away. Their red hoods and rounded canvas superstructures made a jaunty picture. June headed due north into the noon sun, so big and swollen, and so low in the sky, that it could well have passed for a setting sun. In the cold air (the temperature was 50 degrees below zero) the exhaust vapor puffed up like a smoke screen, which a gentle northerly wind fanned out until much of the eastern horizon was obscured. I went below, intending to busy myself with the wind-speed records; but the errand was a piece of self-deception which I could not quite bring off. For perhaps the only moment in my adult life I was conscious of being utterly at loose ends. The shack, which had seemed bright and cheery, now was neither. And obeying an impulse which I had no time to be ashamed of, I rushed up the hatch ladder. Just why, I don't know even now; perhaps for a last look at something alive and moving. Although the cars were by then some distance away, I could still hear the beep beep of the horns and the clatter of the treads, so clearly do sounds carry in that crystal air.
I watched until the noise died out; until the receding specks had dropped for good behind a roll in the Barrier; until only the vanishing exhalations of the vapor remained.
With that the things of the world shrank to nothing. In the southern sky, opposite the waning sun, the night, already settled over the pole, was pushing forth a bulging shadow, blue-black and threatening as a storm sky. Did I see in it the first nervous movements of the aurora australis? I couldn't be sure. A frozen nose and cheeks sent me below before I had time to find out. But, as I slid down the ladder, I was sure of something else, which gave me a bad turn; and that was that in helping the tractor men stow the sledges I had fallen and wrenched my shoulder. The right one was hurting like the devil.
In the shack I stood for a long minute, rubbing the shoulder. Bad business, I reproached myself. Here you're starting the biggest job of your life, and yet, you've blundered and crippled yourself. For things were in an awful mess. The tunnels were a jumble of boxes and fuel drums, and I should be weeks putting them straight. Doubtless they looked shipshape to the tractor men. Hardened to the fearful disorder of their vehicles, they did their house cleaning by booting anything offensive out of the way. So long as there was room to squat, they were content. Well, I couldn't live that way at Advance Base. But only one pair of shoulders was available for all the lifting and moving and shoveling; and they were 50 percent out of commission.
I couldn't just sit and mope. Using one arm as best I could, I started to clean up my own Augean Stable. Absorbed in the task, I forgot the ache in my shoulder. The hours melted away; it was past midnight before I thought of stopping. I paused only long enough to brew a pot of tea and to munch a few crackers. Although I had little to show for the day's work, I could at last move around in the tunnels without tripping over duffel bags, food tins, and bundles of bamboo marker poles. Tomorrow I would commence unpacking the books and racking the medical stores in a handy place. Later on, I would put the food and fuel tunnels in order. The main responsibility, after all, was the meteorological instruments, which, so far, were running smoothly. Every hour I took time out to inspect them, a practice I wanted to become a habit. Already I was regarding them with the warm, covert look reserved for good companions.
The day's work done, I took the luxury of a meditative inventory; and what I saw was good. The means of a secure and profound existence were all handy, in a world I could span in four strides going one way and in three strides going the other. It was not a bright world. The storm lantern hanging from a nail over my bunk burned dimly; and the gasoline pressure lamp, suspended from the ceiling, seemed to concentrate its brilliance all in one patch, making the shadows seem all the darker. But the dimness was rather to my liking. It gave depth to the room, and, somehow, made my possessions seem bigger.
My bunk, fastened to the north wall, was about three feet off the floor, with the head flush against the eastern wall. At the foot of the bunk, on a small table, was the register, a glass-enclosed mechanism of revolving drum and pens which automatically recorded wind direction and velocity as reported by the wind vane and anemometer cups to which it was electrically connected. The dry cells powering the pens and driving the drum were racked underneath. Across the room, in the southeast corner, was a triangular shelf holding the main combination radio transmitter and receiver, with a key fastened near the edge. The transmitter was a neatly constructed, 50-watt, self-excited oscillator which Dyer had assembled himself, and which was powered by a 350-watt, gasoline-driven generator weighing only 35 pounds. The receiver was a superheterodyne of standard make. Above this shelf was a smaller one holding the emergency radio equipment, consisting of two 10-watt transmitters powered by hand-cranked generators, plus two small battery receivers, each good for about a hundred hours. These were stand-by equipment. And above this shelf was a still smaller shelf holding spare parts for the radio.
The east wall, between the head of the bunk and the radio corner, was all shelves -- six, to be exact. The lower ones were stocked with food, tools, books, and other odds and ends. On the top shelves were instruments and chronometers, all placed high and some wrapped in cotton. On the south wall my windproofs, fur mukluks, parka, and pants hung drying from tenpenny nails. Pushed against the middle of the same wall was a food box on which was a portable victrola in a battered green case. The table was also the family board. On the floor in the southwest corner was a box which I called the ice box, since anything put into it would stay frozen. Among other things it then contained were two Virginia hams which my mother had sent me.
The stove was a foot or so out from the west wall, about midway between the door and the triple register. It was an ordinary two-lid, coal-burning caboose stove, except that this one had been converted into an oil burner by fitting a round burner over the grate and rigging a three-gallon gravity tank to feed it. It burned Stoddard solvent, ranking midway between kerosene and gasoline among the petroleum distillates. A liquid fuel was chosen instead of coal because coal was too bulky to haul. From the stove the stack went straight up to within two feet of the ceiling, where it bent and ran along the wall before passing through a vent above the foot of the bunk. By carrying the pipe across the room this way, we thought we were providing the equivalent of a radiator; but the scheme was a clumsy makeshift. Two or three pipe sections were lost on the trail, somewhere between Little America and Advance Base; and, the only reserve sections being of a different size, we had used empty five-gallon tins as joints, cut open at the ends to fit. Ingenious as they were, the connections were scarcely air tight. This crude, inoffensive-looking heating plant held for me the power life and death. Innocent in every rude line, it would nearly kill me a few months hence. And the time would come when I should wonder how I could have been such a fool as not to see what was in plain sight for me to see.
The heating and ventilation of the shack had been a problem from the first. At Little America, where we had given the shack a six weeks' "trial run," both Charlie Murphy and Siple had complained about being made ill by the fumes while they occupied it. This was a warning, since the shack, then above ground, was much better ventilated than it would be underground. Glad for having detected that "bug" in time, I had had the machinist make a new burner. During the month I had lived in the shack at Little America, it had worked fine. Yet, Petersen, the second night at Advance Base, had had a headache and had felt nauseated when he stayed too long inside. But, as nobody else had complained of feeling funny, I had decided that his sickness probably had come from an upset stomach. True, a queer, sickish, oil smell -- the smell peculiar to any oil stove -- was always in the air; and now it was somewhat more noticeable as a result of fumes seeping from the ill-fitting pipe joints. But Siple and I were pretty certain that the ventilation system would eliminate any danger from these fumes. The intake system consisted of a U-shaped pipe, of which one arm stood about three and a half feet above the shack roof. This arm came down outside the west wall, passed under the shack, and rose through a vent in the floor. The inside arm of the U, which was enclosed in a square wooden insulating pillar, rose straight in the middle of the room and opened within a foot or so of the ceiling. The idea was that the cold air, flowing into the shack under gravity, would mix with the warm air at the ceiling and circulate naturally. Otherwise it would lie stagnant on the floor. A three-and-a-half-inch galvanized pipe, cut into the roof, disposed of spent air. I had rather wanted to enlarge this exhaust hole, but didn't dare, remember that the suction effect of a gale always pulls air out of a shack, and probably would pull the noxious fumes from the stove directly into the room as well.
If this setup held the seeds of misfortune, they were not in evidence during my first day alone. On the contrary, I thought the pipe was drawing well. When I put my hand over the end, I could feel a steady flow pouring from it.
About 1 o'clock in the morning, just before turning in, I went topside for a look around. The night was spacious and fine. Numberless stars crowded the sky. I had never seen so many. You had only to reach up and fill your hands with the bright pebbles. Earlier, a monstrous red moon had climbed into the northern quadrant, but it was gone by then. The stars were everywhere. A sailor's sky, I thought, commanded by the Southern Cross and the wheeling constellations of Hydrus, Orion, and Triangulum drifting ever so slowly. It was a lovely motion to watch. And all this was mine: the stars, the constellations, even the earth as it turned on its axis. If great inward peace and exhilaration can exist together, then this, I decided my first night alone, was what should posses the senses.
No, it wasn't going to be half bad. A man had no need of the world here -- certainly not the world of commonplace manners and accustomed security. The Barrier, austere as platinum, was world enough; and onto it I had trespassed but little. The only things of mine that showed were the radio antenna, the twelve-foot anemometer pole surmounted by the silver weather vane, and the aluminum wind cups, the beehive instrument shelter for the thermometers and recording barograph, and the ventilator pipes and stove-pipe sticking above the shack roof. Without taking more than a few steps, I could touch them all; and a traveler on a darkish night might pass at twenty yards and miss them entirely. Yet, wasn't this really enough? It occurred to me then that half the confusion in the world comes from not knowing how little we need.
That night, anyway, I had no consciousness of missing conventional sounds and stirrings. I was as methodical as any family man following his ordinary routine. I turned off the valve in the stove and put out the fire. Then I undressed, draping my clothes over a chair. I remember cussing inwardly when my bare feet touched the floor, and certainly I stepped lively in crossing the shack to open the door for ventilation and in leaping into the sleeping bag before the inflowing cold blast overtook me. The bag at first was cold, as it always was, from accumulated body moisture. And, while I waited for it to warm up to a tolerable temperature and massaged the protesting shoulder and felt around to make sure that I hadn't forgotten the flashlight in case I had to get up, my mind was wondering whether my family was all right and about the things I'd do in the morning. But, most of all, it kept dropping back to the tractor crew somewhere between me and Little America, and I couldn't help reproaching myself for having kept them so long.
Out of these rambling notions sprang an awful thought. Although I had been through all the gear, I couldn't recall seeing either the cook book or the alarm clock. "Good God!" I exclaimed, and the explosive echo of the words, the first spoken aloud since the tractors had left, almost brought me out of the bunk. In all the planning, the scrutinizing of every detail, the checking and the double checking, could we have forgotten these two common but indispensable tools? Telling the time was no problem. I had three chronometers, plus a wrist watch. What worried me was getting up in the morning for the 8 o'clock weather observations, now that the winter night was coming, and the twenty-four hours of the day would all be nearly the same. As for the cook book, I could do without it; yes, indeed. But maybe not. Although I upended my memory, I couldn't remember ever attempting anything more elaborate than ham and eggs over the kitchen range, or a steak over a camp fire, or pemmican hoosh on the trail. A civilized man, a city-dweller used to servants, an explorer accustomed to a camp cook at least -- or what passed for one -- I might have to choose between starving to death or slowly going mad on a diet of cereal and canned corn beef. Thank heaven, there was no lack of can openers. Corey had included at least a dozen, and they were scattered among the stores to avoid any chance of their being lost all at once.
So why, I asked myself, weary the mind with small reproaches? Sufficient unto the day was the evil. The assets, after all, were many. Remembering the toilet some thirty-five feet down the food tunnel, I drew comfort from the fact that my kidneys were sound.
